CATransplant
- Joined
- Feb 26, 2005
- 6,319
That engine is almost identical to my RDS-20, a 1958 35hp Johnson. There are several of us here with that engine type.<br /><br />The big problem is that you can't hook up the earmuff-type cuffs to supply water to this engine, and you shouldn't even try to start it dry.<br /><br />Build a sturdy, sturdy stand for the engine out of lumber, and put the engine on that, or install it on the transom of a boat. Then, put a large trashcan under the engine, with enough water to cover three or four inches above the horizontal plate above the propellor. That will do to test run the engine, but don't start it dry.<br /><br />Since you don't know how long the engine has sat, everyone here will advise you to change the water pump impeller before going any further. It's good advice. You'll need a workshop manual for this engine, as well. It's a must-have item.<br /><br />What you can do, before changing the impeller, though, is to put the engine in the water, pull the spark plug wires and spark plugs, and check for spark on both cylinders, by grounding the spark plug threads and cranking the engine with the pull start rope. You'll probably need a helper, either to watch for spark or to pull. If you have a good strong spark on both plugs, you're good to go. further.<br /><br />After you get the manual and have the new impeller installed, you have a couple of options. Some people will suggest that you clean the carburetor before going further. You don't necessarily have to do that. It's worth trying to start the engine to see if the carb is OK. Many times, it is. If not, then you can always clean it and install the carb kit.<br /><br />Impellers and carb kits are available from your local OMC dealer, or from a NAPA autoparts store. The aftermarket company that makes them is Sierra. They also have tune-up kits for your engine.<br /><br />The wiring harness is another problem. That part is not available new, as far as I know. It connects to a box, which contains the necessary starter solenoid for this motor. You'll have to dig up a good used unit. A good place to start is at an outboard junkyard, like Twin Cities Outboard (check Google). They'll have this stuff, I can pretty much guarantee. The unit uses a 12-volt battery.<br /><br />It is possible to rewire the thing, but I really recommend using the factory plug and wiring harness. It's worth it.<br /><br />You're going to have lots of questions, I can guarantee, as you go. Ask them here and you'll get the answers you need.<br /><br />BTW: That engine uses a 24:1 fuel
il mix. That's 1 quart of TCW3 Outboard oil to 6 gallons of 87-octane gasoline. Get the oil at any marine supply place or even WalMart.<br /><br />Ask away...we'll help.
