ebear
- Joined
- Sep 10, 2007
- 57
O.K. this may take a second. I have/Had a 1986, 3.0L in my boat. A month ago I had the impeller break off a fin and it went into the intake side of the pump,block it off and over heat the motor.
I had a 1996, 3.0L motor sitting in the garage so I swapped them out. [ now, all I did was pull the old motor out and drop in the 96 using the front motor bracket from the 86 motor.] everything slid together seemingly perfect. exept that I came up with a vibration. I couldn't locate it so I kinda let it go.
Well, yesterday I went out and ran 3000 rpm for 20 minutes, came to idle for 30 seconds then shut it down.[ It ran perfect the whole time.] When I shut it down, It ran on/backfired. I didn't think much of it till I went to start it again.
Well it ends up that it won't turn over at all. I pulled the plugs to make it easier to turn over and I found water in #4 cylinder and the plug holes sounded as if the motor was breathing in the waves. so I could only assume that My baffel is defective. Now, i can remove the starter and use a screwdriver to move the flywheel. every couple degrees it moves freely [plugs are removed] but mostly it turns hard. what could it be.
so here's my questions.
1. could I have seized the outdrive/ gimbal berring from not aligning it?
2. did I even need to align it being that the blocks were identical and I used the original brackets?
3. could the runon/ backfire have caused damage to the motor?
The reason I'm asking this is because I can"t decide if I should pull the outdrive or the motor. The motor ran great but I'm afraid that the vibration was coming from the gimbal area and it ended up seizing it. Or the backfire caused a spun berring or somthing.Any input would be great.
thankyou
thankyou
