what size fuel line fit choke 1989 90 hp johnson
johnson89
need to replace my very small fuel line ,looks like 1/16 inside diam. looked all over the internet and can't find anything that small except weed eater line and its plastic. Not sure if this would be safe to used being next to the engine block.I want to replace all the small lines on the engine. thanks for any help
Most boat shops would cut that off a 50' roll.-----Not scarce at all.----What is wrong with the lines on your motor now ?---Or replacing just because they are old ?
johnson89
very old,getting a few drops of gas in bottom under the carb. and found a line with a crack in it.. Its one of recirculation lines. I will stop by a marine shop in a day or so see what they have.
