What size motor can I
ifishinwater
GUYS
I've a 15ft 1965 Starcraft ...has 40hp on it now.
Want to put a 50hp on it. The weight of the motors about the same.
Boat is in great shape...
What was the hp rating for that boat? Don't want to get a fine from the water patrol. One boat guy satd the boat could handle a 50hp. another said what about a 30hp.....I would like the 50hp but if just rated for a 40hp could live with that.
5150abf
Re: What size motor can I
The weight of the motor is not the problem, it is the thrust the motor puts out.
That is a pretty old hull to and as you know things generally get weaker over time so even the rated engine may be too much for it.
I don't know for sure but I would say 40 is pushing it and 50 would for sure be too big.
My 2 pennies.
tashasdaddy
The United States Coast Guard has an opinion on this frequently asked question, and their answer from their website is reproduced below:
Can I use a bigger motor on my boat than what it's rated for?
It is not a violation of Coast Guard regulations to install or use an engine larger than specified on the capacity label, but there may be state regulations prohibiting it, and restrictions from your own insurance company regarding this.
There are no Coast Guard regulations against exceeding the safe loading capacity, however, there may be State regulations or restrictions from your insurance company which prohibit this. There is a Coast Guard regulation that gives Coast Guard Boarding Officers the power to terminate the use of a boat (send it back to shore) if, in the judgment of the Boarding Officer, the boat is overloaded. There is no fine for this, unless the operator refuses the Boarding Officer's order. We certainly hope that you will abide by the rating, as overloading may lead to capsizing or swamping of the boat.
NOTE: The Coast Guard Capacity Information label is required only on monohull boats less than 20' in length. The label is not required on multi-hull boats, pontoon boats (catamarans), or on any sailboats, canoes, kayaks, or inflatable boats, regardless of length.
As the Coast Guard mentions, local regulations may apply. For example, in the state of Ohio one should be guided by this regulation:
Capacity Plates
(ORC 1547.39 & ORC 1547-40)
No person shall operate or permit operation of a watercraft in excess of any of the stated limits on the capacity plate. When no capacity plate exists, no person shall operate or permit operation of a watercraft if a reasonably prudent person would believe the total load aboard or the total horsepower of any motor or engine presents a risk of physical harm to persons or property.
you can determine your capacity here. http://forums.iboats.com/showthread.php?t=191283
ifishinwater
I went the site you gave me Lots of good information... thanks
Put my numbers are stern 4.91' length 14.58' my factor # was 72 I came up with 54hp max for the boat. On the title said 15' & I think it is a bit less in length
Thank you both for the help. Question what is the gussetted area on a boat.
I'm not sure so I ask this question.
