What size motor?
alderman
Spring is getting near and my fishing fever higher, I need some help trying to figure out what size trolling motor to buy. I have checked the previous post and still somewhat confused.<br />The boat is a 1963 starcraft alum. vee I will be mounting it on the transom, most of the time there are 3 people plus gear. I have two outboards that I use depending on lakes and rivers a 5hp and a 25 hp.<br />Some of the smaller lakes only permit elec. motors and I would more then likley also use it in the Missouri river. I'am not looking for speed only to get around on small lakes and maybe as backup in the river. I don't want to spend a lot but want something that will work for both applications. <br />Any ideas on thrust, brands and 12 volt versus 24 volt?<br />Thanks in advance for all replies.<br />Ray
Silvertip
Re: What size motor?
You are not giving us much to go on regarding the size/weight of your boat. If this is a 14/15 foot row boat a 30# thrust motor would do the job. If you are in a 15/16 foot you would probably use a 36#. Go to Minnkotas web site. They have selection charts that will help.
alderman
Upinsmoke, thanks for the reply. It is just a 14 foot fishing boat nothing fancy. Just don't want to buy something too small, and don't need anything to big. I'll check out the minnkotas web site. <br />Thanks again for the help.<br />Ray
