what size outboard motor is correct?
I need to replace my outboard on my 23 foot center consol Sea Era boat. What is the smallest sensible outboard size? What is recommended? I use the boat in the ocean near the shore. Mostly 40 minute runs from one island to another. Thank you!
Frugal Floater
Re: what size outboard motor is correct?
There is a big range in weight with 23' cc boats...what exact model is it?
Most would probably disagree with me, but I think choosing the lower end of the recommended HP is the best cost/benefit option. You probably know that 1-2 foot waves are rare in big water and it is not very often you will be able to go 3/4 throttle without a knee replacement.
225HP should do the trick (depending on weight...if dry weight is over 2,500 you may want to up that). In any case, a new motor will run you $8,000 to $12,000 depending on stroke and brand.
I am sure the 2-stroke vs 4-stroke will come up (beaten like a dead horse in this forum...just search). I am more than happy with my 2005 90hp 2-stroke and it is not as loud/environmentally unfriendly as most make it out to be...I know it will outrun a 115 4-stroke with my boat having 1 more 200lb person on board. My friend has the exact same boat just a year older and with the 115.
Frugal Floater
Now I see you posted the model boat...No change in my recommendation...May be able to go with as little as 180HP based on same model boats I see online.
deejaycee_2000
on a 23 foot, nothing less than a 175hp, but a nice 300hp HPDi yamaha would do the job very nicely ........
tashasdaddy
if the cost doesn't kill you why not 2 150's. would be alot safer.
