What size prop for '77 9.9hp Johnson
Vapour1ze
Got a 9.9 2 stroke, 77 johnson, wondering what would be the best replacement, I use it in a very shallow river, and hit sometimes, and its usually just me and a buddy with a empty boat, 12' Aluminum Sea Nymph flat bottom, what is my best bet? Thanks
Tim Frank
Re: What size prop for '77 9.9hp Johnson
Check right here on iboats....they have a prop section in the store.
dazk14
Ensign
This should be about right...
http://boatpropellers.iboats.com/Ev...andard&**********=174397052&*******=330842317
All have certain advantages. At least 2 of these will allow you to raise the motor higher on the transom ~1", which might give that little bit of draft marginal that's needed.
The 4 blade will also plane with less stern squatting, if that's when you're hitting.
If you can provide more specific info - it will add to the likelihood of hitting a winner in one shot.
Find the size of the current prop you are using. It's likely a 3 blade 9 or 10 inch pitch.
Do you know your max WOT RPM's.
Do you want to plane quicker and is that when you usually hit bottom.
How long has your current Aluminum prop held up in use.
That's a start.
Vapour1ze
current prop has been on the motor since 77, lol. it was my grandpas and yea i would like to plane a lot faster then what I am now, and it is currently a 3 blade and probably about 8 inches ?
Tim Frank
There's maybe better help on this in the Prop forum just down the hall.
dazk14
Ensign
Need those numbers dia x pitch, should be stamped on the side. Can you borrow a tach to get your WOT number?
Moving it over to the prop section wouldn't hurt either although I don't look at that section.
