BanjoRed145
- Joined
- Jan 24, 2010
- 11
What size shear pin do I need for a 1957 35 Horsepower motor? Also, what spark plugs should I be using? The model number is RDE-19.
If by shear pin you mean flywheel key, you cannot use the ones at hardware stores. They aren't hardened nor strong enough. Just take your year and model number to a dealer and they'll give you the correct pin
The manual calls out a J4C, but I don't think those are good for anything but fishing weights. I would go with a J6C
Not sure about shear pin size though.
I was always told by the marine shops that the higher the number the hotter the plug. Is this your experience? I'm told it is because the center electrode insulation is thinner or fatter. The fatter insulator will dissipate the heat faster so it is a colder plug Therefore it may be a C4J as compared to a C6J.
I am not going to run thermos-stats for a while until I see how my twin 61 Johnsons are going to operate so I may try the C6J series plug for a hotter heat range.
Do you think my analogy is correct.
cheers
"Shear pin" refers to the pin used to drive the propeller. Actually, the motor in question does not have a "shear" pin, but a "drive" pin. It is made of stainless steel and is not intended to shear except possibly under very severe circumstances. The rubber hub in the propeller absorbs other shocks and impacts.
OK, having preached all that, the drive pin is part number 304575 and is 1/4" diameter x 1-15/32" long, stainless steel. Used in 28-33-35-40hp motors for many years
Not that I like correcting people, but the flywheel keys are supposed to be soft, not hardened. The taper is what provides the "lock" between the crank and flywheel, the key is for position only so your timing is correct. If torqued correctly, you do not even really need the key theoretically. A lot of them are made from aluminum so they shear when you hit something hard. Rick
