What speed should I expect????????
kshelly
I know speed doesn't necessarily indicate proper performance of your boat/motor combo, but generally, what speed should I expect to get in a 19' fiberglass bow rider with a 115 hp johnson O/B? I'm currently doing about 27MPH at 4900 RPM. That's with 1 adult, 2 children and basic equipment.
Re: What speed should I expect????????
You ain't doing Too Bad.......<br />RPMs Sounds a Little Low..........<br />You Might have a couple more left in it.......
kshelly
Yeah, I know I'm on the low end of recommended RPM. I went from a 19 pitch prop, to a 17 and now run a 15. Time for a 13???
youngboater
If it won't cost you anything why not go for it.<br />Just be careful and watch the tach. I run a 19incher on a 75 HP 17' aluminum and get about 35MPH (4,900 RPMs smack in the recommended range for me) Let us know what happens.
Solittle
I suspect that your motor is not up to snuff if you are only getting 4900 rpm with a 15" prop.
