Re: What symtoms will coil give if bad??
also the coil on the motor you have rarely ever gives any trouble ,i have only ever seen a very few go bad . you may also want to look at the distributor cap it could also be the source of your problem .also still a possibility it could be in the wiring or the key switch,in order to check this just remove the ground wire connected to the terminal on the side of the distributor,and see what happens.
