What temp to check compression?
bretto
Do you check it when the engine is at full operating temp or cold. Does comression normally go up when after the engine is warm or visa-versa?
Thanks,
Brett
baxtr
Re: What temp to check compression?
you can check it cold, as your motor gets warmer, the rings do expand,that is why there is a gap in the ring, so they don't expand and get too tight in the cylinder.
roscoe
Warm is more consistent.
Do it cold if you can't warm it up.
Readings tend to be higher when the engine is warm.
bretto
So I checked the compression last night cold and got all 3 at 115 or so #'s. So is it safe to assume that the compression will be more so when at full running temp? Are those good #'s? This is on a '83 Force 85 by the way. Also I sorta goofed and didnt ground out the plug wires when I did it, do you think I damaged the coils at all?
Thanks all,
Brett
roscoe
Compression is fine.
Damage? don't know.
