what the difference. cobra outdrives
whywhyzed
Banned
Re: what the difference. cobra outdrives
between 6 & 8 - nothing.
early 4 cylinder Cobras had a different lower gearcase, 13 spline propshaft, different bearings, bearing carrier.... pretty much all unique parts - some parts shared with Evinrude/Johnson V4 outboard lowers
Later 4 cylinders used the 15 spline V6 parts - not sure when that began.. 1990 maybe?
Don S
What are you wanting to do?????
Two86OMCs
Actually I had this same question, I am looking into getting a new out drive and found a really cheap cobra outdrive off of a 4cyl 2.3l omc. I want to put it on my 4.3l omc. What am I looking at as far as fitting it up? Will it work? Gearing shouldn't be a huge issue since I can just get a more highly pitched blade to compensate a little for a slower spinning prop. Right now $2000 bucks to get the outdrive replaced/rebuilt just isn't in my boating budget.
Don S
If you have a question, don't just tack onto the end of someone elses post, ask your question in a new thread.
NO, it won't work.
metro3pilot
Besides the gear ratio ..I heard the 4cyl had a smaller case for the lower unit as well as less sturdy gears.
It seems that on ebay the average for a used 4.3 outdrive complete is around $ 1200.00 plus shipping, buyer beware
at reputable dealers rebuilt that, outdrive seem to average $ 2500.00 to
$ 3500.00
it would not make economic sense for a company to tool a factory for different product lines, as well as the added inventory costs of different outdrives if a prop swap could make up for gear ratios.
Two86OMCs
True, factories would never do something as irrational as that. However, theoretically if the drive is spinning slower all you have to do is put a more aggressively pitched blade on the end of that spinning shaft to make up the difference. The problem is that you get into hydrodynamic issues with how efficiently the larger prop moves through the water. Airplanes use similar principles, a jet uses a very small blade spinning at very high speeds to move quickly while helicopters use huge blades moving slowly in order to lift heavy objects straight up in the air. Both have their advantages. A slower spinning prop on a boat that has a very high pitch angle may not give you a very good top speed but it would have plenty of torque. Think of a tug boat vs a hydroplane. Would this not work because they would not bolt up the same or do you think that the gearing in the 4 cylinder out drive would be too weak to handle the extra 60 or 70 hp? I mean the HP jump is not THAT significant. I'm not trying to make a perfect boat, just something that will run for a few summers with an out drive I can grab for 100 bucks.
metro3pilot
I have heard ... the case itself is smaller and the gears are also less sturdy than the V6 / V8 case and gears
I'm pretty sure it will bolt up ok ...and a reprop may work, but what damage are you doing to your engine ?
you will never achieve the correct RPM for WOT .... or worse, you could go to far with the RPMS and start bending expensive parts in the engine ...
:rolleyes:
