stanfordky
- Joined
- May 7, 2011
- 10
well i took my boat to a certified mechanic here in ky because i noticed that i had water in my lower unit and i had fishing line around the prop. So i figured that the prop seal was bad. keep in mind that my motor has always ran like a top with no issue. he said that since he has it apart that it would be a good idea to put in new water pump and i agreed. my boss went to pick up my boat and when he got there they said that they couldnt get it to run to check it. brought to me and the all the wires from the starting battery was removed the battery bolts where missing, the gas line was unhooked from the motor, and the circulating tube to the pee hole was off. well i put it all togeather and took it to the lake, fired right up. well started out down the lake and the horn started to go off, i stoped seen that the motor was smoking and that it wasnt putting out any water. i took it back to mechanic and told him the situation he looked at the motor and called me today saying that the plate was on upside down on the water pump causing it to chew up the water impeller, but he didnt do it, and my motor is shot and lost compression on the bottom cylinder which was 145, 140 and 140. my motor always ran great a pumped water like a new boat. he says that the plate was put on upside down before he serviced it. what to do know.
