Greetings! I'm new to this forum. Perhaps like many of you, I was moved to join because I need your advice. I hope to return the favor many times over.
Yesterday, I drove a Wellcraft equipped with a 2001 model year Volvo 5.0GL with an SX outdrive. Specifically, I drove it aground navigating on a moonless night. And yes, my GPS was resting comfortably in my truck.
The propeller -- a 15X17 aluminum unit, was damaged. A quarter-sized piece broke off from the tip. Otherwise, the tips were bent moderately with one leading edge warped slightly. I nursed the boat back and changed the prop and the boat did the following:
So that means something's wrong! Right? The outdrive was scratched, but the skeg was not broken or even bent. The hull was untouched. I was going about 15 MPH and it appeared that I hit no large rocks.
Talk to me about the long term latent damage that has occured. Confirm my suspicion that something serious has happened.
I KNOW I'm in trouble. At least that's what I suspect. Here's why:
There is no way in hell that Volvo designed this unit to tolerate running aground. It makes no business sense to do that.
I removed the propeller (that I just changed) and ran the boat to observe the propshaft for evidence of bending. There is a slight wobble. So very slight -- less than 1/16th of an inch. Is THAT normal? Should you be able to detect any run-out or wobble of the propshaft?
I'm debating on whether to file an insurance claim to have the unit rebuilt. I am admittedly anal about boat maintainace (soon to be replaced by anality about GPS use and night operation). All kidding aside, I'm sure that there is nothing wrong, but I can't help but believe that running aground will cause the outdrive to fall apart in a few years like the police cruiser in the Blues Brothers. If I don't file a claim now, I will lose the ability to get it fixed. Any insight would be appreciated.
Siggie
- Ran fine with no detectable difference in vibration.
- Shifted smoothly.
- Made no new noises.
- And the drive raises and lowers normally.
Siggie
