Re: What to do with my prop
seems like something else is happening -- the typical change is 200-300 RPM for the pitch change-- assuming the same design and same construction of prop. If you changed materials --- say stainless to aluminum, you have other issues.
Do you have the old prop? and is it in reasonable good condition.
If so -- I suggest having a double cup put on it -- and see how much this brings down the rpm -- (assuming it has not already been cupped) ---
That is a cheap thing to try --- should only be $30-50 at a typical shop -- more maybe if you have the prop reconditioned at the same time -- but still under a hundred.
