Hi - have 2 quick questions. Did a search but couldn't find my answer. I have an 18 foot '88 Glastron with same year Mercury Black Max 150hp. I just got the water pump impellor and lower gear oil replaced yesterday since I don't have the previous maint records. They also did a performance test and everything is good. Compression around 120 on all cylinders, spark, fuel, all good. I have noticed that the steering gear/rods are pretty dry at the outboard itself. What can I use to lube them? I have a repair manual but it doesn't specify how to lube them and what to use. I do not see any grease zerks for it either.
My 2nd newbie question is I bought the bought to be used for watersports. It has a quicksilver 19p 3-blade SS prop on it now and I top out around 5200 rpms WOT at 44-45 mph GPS. I was told by the place that checked out my boat that I could drop down to a 18p 4-blade or a 17p 3-blade for better holeshot performance. The 19p right now just drags me when trying to slalom ski. No holeshot power at all right now. Any recommendations on prop selection? 3blade vs. 4blade? Thanks in advance!! This is a GREAT site!
