trayscool
- Joined
- Mar 31, 2008
- 46
Hello again iboats! Thanks for your help as always.
I just purchased my 3rd boat, a 1999 seaswirl striper. The boat is great and came rigged to the gills with all kinds of extras and a 15hp 4 stroke kicker motor. the problem is the kicker is mounted on the driver side of the boat. When you get in to take off, the boat lists heavy to the right side, and with self bailing decks actually fills up with water a little until to come to a plane. you have trim the boat out to balance the heavy side as well.
I am thinking about adding some ballast to even out the load. I have some lead weights that I can install safely in the left side rear of the hull or should I use something else? the lead is toxic. I was thinking about sandbags maybe, but they will get waterlogged and moldy eventually. Have any ideas??
here is a picture for good measure. thanks in advance....
