what to use for sealant?
tuna troller
hi, i notched out my transom, and now want to seal the wood before i glass it. what should i use???
thanks
ondarvr
Re: what to use for sealant?
Nothing, anything you put on the wood other than the resin you plan to glass it with will create bonding problems.
tuna troller
what would you recommend i do for the glass? the area is 18 inches long x 2 inches wide.
thanks
oops!
depending on what resin you use....epoxy or poly.....will determine your glass...
if you use poly......matt, cloth , matt....
epoxy.....cloth , cloth.....
i would think poly is more than adaquate for this job.....but its your call
