Since the 97 uses a plastic timing cover what do u use to time the engine?
Manually turn the engine so that the mark on the harmonic balance aligns with the mark on the timing cover. Now get some white paint and make new marks on the balancer and the engine some place that you can see better.I have an adjustable timing light. The problem i ran into was the location of the timing mark on the cover is so far back that i can barley see it with a timing lite. My gas tank is about 4 inches from the crankshaft pulley so it's real tight to try and get a timing lite in there let alone being able to c the mark at the same time.
