What type of fitting
test port.jpg Below is a fitting on a 9000 psi pressure gauge and I need to know what kind/type it is. Trying to find an adapter to go from the gauge to an npt fitting
Tim Frank
What is the gauge diameter?
With no size reference, it looks like a standard pipe thread...pitch compared to dia. suggests 1/2"-14 NP and it is hard to tell whether it is straight or tapered thread....my guess would be NPS.
If it is a brand-name manufacturer you should be able to get specs online.
With some more searching and help from HEF I figured out what it is. The fitting is made by Brennen (British) and they call it a gauge fitting or connector. Did find they also made an adapter DGA2404.04. The threading is BSPP with a different end for an O ring. Found one on Amazon for $22 and will be 2 to 3 weeks to get it.
Check your local parker hydraulic store
No such thing as "local parker" here. I just ordered one online
dolluper
In your neck of the woods Harbour Freight. . In Canada Princess Auto same thing
