Re: What type of grease do you use?
marine grease is either going to be based on an aluminum complex or lithium complex. If it is aluminum complex, that is 100% compatible with a common lithium complex grease. And obviously if its already a lithium complex, no problems there.
(depending on who you ask, lithium complex is actually compatible with ANY grease, at least for a relatively lower stress application like a wheel bearing. The chart below only means the combination will meet or exceed the specification of either grease by itself, even when used at the ragged edge of its performance envelope.)
