What type of grease fitting is this on my universal joint?
littleguydave
I asked this question in another forum of mine but I figured this would be a lot more to the point with more success. I just replaced my gimbal bearing and I would like to lube my universal joints. The grease fitting looks like this
Ayuh,... It appears to be a pressed in fittin', with the end busted off,...
Might wanta get new u-joints,...
wrench 3
We don't know what year you have but the newer ones aren't greaseble from the factory.
littleguydave
I believe my engine is a 94 4.3L v6. This is on an 18' crownline, '95 model. I am new to boating and using youtube and google to get me through this, and of course, you guys.
I will rent a ball joint press or ujoint press if I need to, but I would prefer grease if possible
wrench 3
'94 would have been greaseble. Maybe someone put in a rebuilt unit.
That would be a screw in plug with a breakaway head. You may be able to remove it with vicegrips and install a grease fitting. You could try tapping it around with a hammer and chisel to get it started.
With the pic that close, it looks like the plastic that is used to lock in the caps into the yoke
stonyloam
Yeah, I kinda thought the same thing, looks like a cap. Are you sure the fitting is not under that.
littleguydave
I tried to pry it with a screw driver ad nothing. There is definitely no plastic. Then I used small channel locks to try to twist it out, and nothing
Bt Doctur
Greasable U joiints are available, what drive?
External snap ring type Alpha GEN II, Bravo 18-6406
Internal C clip to Ser# up to B418818 18-2104
Internal C clip Ser # 418819 and above 18-2174
littleguydave
I found a guy who will do them for $100 if I buy the part. Is there a local place like autozone or dicks that would have a decent bearing?
Bt Doctur
without telling us the serial number of the drive, we can only guess
charleso
Auto parts stores would more than likely have a substitute, but get the old joint out and take with you for matching it up. Also make sure the new one is greaseable.
Rick Stephens
In the Adults Only section is a post by Fishermark that lists u-jiont crossover part numbers:
SPICER# 5-1306X
ROCKFORD# K1306
DETROIT# 7260
NEAPCO# 1-6300 / 1-6301
PRECISION (MOOG)# 315G
TRW (FEDERAL MOGUL)# 20030 / 20030P
I still can't believe most people won't look in the Adults Only reference section......
littleguydave
I never checked it because I assumed it was not safe for work.
Guys I cannot find a video on how to remove the ujoint assembly. I took the top plate off and I see a nut which may be a retaining nut, but that's where I am stuck. I dont have a took to take that off or torque it back on
