What type of oil to run in 302 Mercruiser engine
Status
Not open for further replies.
conk3416
I have a 302 Ford Mercruiser Engine in a 1985 Sylvan boat. But I think the motor is from the early 70's. I was wondering what type and weight oil I should use.
Thanks Andrew
Bifflefan
Re: What type of oil to run in 302 Mercruiser engine
the old stand by of
10w30 or
20w40 sounds good.
Dont let the "w" fool you into thinking its for winter. it means that the oil is 10 or 20 weight when its cool (cold) and then thickens when it gets hotter.
conk3416
thank you, I am using the boat to pull tubes and wakeboarding so it will have a load on it most of the time. Would the thicker or thinner oil be better.
Thanks Andrew
Don S
conk3416
yes it is a ford motor. The previous owner of boat pulled out the 4 cyl. engine that was in boat originally and put in the 302 mercruiser with a merc 888 outdrive. And thanks for the link
farmeloj
Interesting, Mercruiser didn't use the Ford engines after 1977. Sure you have a Ford there?
Either way, here is Mercruisers latest information on the type of oil you use. Trust me, any of them are as good as anything used in the mid 70's.
http://dc120.4shared.com/download/118501097/9b0c2296/05-02_New_oil_recommendations.pdf
Perhaps you misunderstood. He said it was 1970 in the beginning. I hav eone also I always had the best luck with 10w30.
sethjon
Use 10/40. make it a top brand. Don't buy cheap oil.
haulnazz15
I use SAE 30, as that is what was specified my Mercruiser long ago. Most any oil will work, but you can't go wrong with SAE 30.
Status
