what type oil filter?
kyhemi57
96 mercruiser 3.0lx alpha one
need to know what kind of oil filter/type of oil(the old filter in it now is a sierra 18-7876)? can i buy at walmart? or whats the comparable one to a vehicle filter?
Also, what kind of oil for outdrive?
Thanks.
dubs283
Re: what type oil filter?
go to local merc dealer
get mercruiser sterndrive oil filter for GM V-8, its the same as the 4 Cyl
25W-40 oil, or SAE 30
quicksilver high performance gear lube is the ONLY lube i would put in an alpha drive
HT32BSX115
And you can get the above stuff at most Walmarts
Cheers Rick
kyhemi57
how much gear lube will i need?
what size impeller will I need?
Ayuh,.... You'll need 2 qts. to do the job, 'n the pump to put it in...
You need an impeller to fit yer Alpha 1, Gen.II...
kyhemi57
Can I just buy impeller or do I have to have the whole repair kit with seals, etc?
Ayuh,... Gaskets, 'n o-rings are not known to be Reusable parts...
