What washers and spacers are supposed to be on Force 125 prop shaft
baxtr
I posted this on the prop board also, I think I will get more help here though.
Could anyone tell me what washers and/or spacers are required on a 1989 Force 125 prop shaft?
I have the big thrust washer ( the thick one with the step in it), then the prop, then a splined spacer, then a small washer befor the nut.
the small washer on the end that the nut tightens against is only big enough to go over the threads, not the splined area so when I tighten the nut down, it tightens to the washer which tightens to the top of the splines, not tight to the splined washer at the prop. I have some play in the prop, about 3/16 that the prop will slide in and out. Am I missing something? some sort of spacer? or is the splined spacer I have worn too thin, or the wrong one all together?
thanks,
Brian
Reel-Fun
Re: What washers and spacers are supposed to be on Force 125 prop shaft
You deffinatly dont want that kind of play in your prop, im thinknig that washer that does not fit is not suposed to be there or is wrong ill look at mine when i get home this after as i have the same year and same motor. i have the lower unit off right now ill post back this afternoon or tomorrow.
baxtr
If it is possible to get some numbers off of your washers, spacers, or whatever is actually there, I would appreciate it.
Thanks
Brian
Reel-Fun
im running the old closed end prop right now my old one was your type it had the 2 step then the prop then the knotched spacer then a washer then a nut, what i run now is the 2 step washer prop then flair then nut if u need i will take pics of my current setup as well as my old one. seems that u have the right amount of spacers just not the right thickness...
