what washers and spacers for 1989 force 125 prop shaft?
baxtr
Could anyone tell me what washers and/or spacers are required on a 1989 Force 125 prop shaft?
I have the big thrust washer ( the thick one with the step in it), then the prop, then a splined spacer, then a small washer befor the nut.
the small washer on the end that the nut tightens against is only big enough to go over the threads, not the splined area so when I tighten the nut down, it tightens to the washer which tightens to the top of the splines, not tight to the splined washer at the prop. I have some play in the prop, about 3/16 that the prop will slide in and out. Am I missing something? some sort of spacer? or is the splined spacer I have worn too thin, or the wrong one all together?
thanks,
Brian
