What would we in the UK call kerosene?
JIM MAW 2
I am confused as to what kerosene actually is.....<br />would it be what we call paraffin or could it be <br />heating oil or what we call methylated spirit?. I had assumed it was paraffin but I have just purchased some injector cleaning fluid for the car and as I looked at the label it said it contained kerosene then in bracket's petroleum and on one of the thread's a few day's ago it was said that British Seagull engine's could run on kerosene without any additional oil by doubling the thickness of the head gasket and as the owner of several of these engine's I am curious to find<br />out what kerosene is.
Mark R Groves
Re: What would we in the UK call kerosene?
I believe the what we in the U.S. call kerosine is what you call paraffin. Basically, its the fuel burned in the old pre-electricity lamps.
almost retired again
Hi Jim,<br />Kerosine is almost the same as what we call #1 diesel it may be a little more refined,but I don't know what you in the UK would call it.
Stever
Hello Jim!<br /><br />Kerosene (also formerly known as coal oil) in the US, is same as your paraffin oil in the UK. The primary current use in the US (by individuals) is as a fuel for portable heating units and oil lamps - both very popular during the long, cold winters in the rural areas of the northern US (did I mention that we are expecting more snow tomorrow?). It is also used as a thinning agent of petroleum based products. Commercially, various grades include JP-5, JP-8, Jet-A, Jet-Q for aircraft fuels. As "almost retired again" indicated above, kerosene is a slightly higher refinement than our grade #1 diesel fuel oil used in our diesel land-based vehicles (there are less sulfur compounds in kerosene than #1 - less noxious odors when burned).<br /><br />Cheers!<br /><br />Stever
Ross J
Kerosine, also spelled KEROSENE, also called PARAFFIN, PARAFFIN OIL, or COAL OIL, flammable pale-yellow or colourless oily liquid with a not unpleasant, characteristic odour.<br />It is obtained from petroleum and used for burning in lamps and domestic heaters or furnaces, as a fuel or fuel component for jet engines, and as a solvent for greases and insecticides.<br />Kerosine accounts for between 10 and 25 per-cent of the total volume of crude petroleum. It is separated physically from the other portions by fractional distillation. It can also be produced chemically by cracking, or decomposing, the less volatile portions of mineral oils at atmospheric pressure and elevated temperatures.<br />Kerosine was first manufactured in the 1850’s from coal tar and shale oils, but petroleum became the major source after 1859 when E. L. Drake drilled the first petroleum well in Pennsylvania. Because of its use in lamps, kerosene was the major refinery product until the automobile made gasoline important.<br />Chemically, kerosene is a mixture of hydrocarbons; the chemical composition depends on its source, but usually it consists of about 10 different hydrocarbons, each containing from 10 to 16 carbon atoms per molecule; the constituents include n-dodecane, alkyl benzines, and naphthalene and its derivatives. Kerosine is less volatile than gasoline; it boils between about 140 and 320 degrees C (285 and 610 degrees F).<br /><br />Taken from “The Encyclopaedia Britannica”<br /><br />Ross
JIM MAW 2
Thank's to all for your excellent answer's. Jim
