big boat little motor
- Joined
- May 21, 2009
- 54
Earlier this season I had picked up a new to me 97 Lowe 19' deck boat with a 89 Johnson 88spl outboard from a friend of mine that had recently upgraded to new 26' sea ray. I knew when I bought this boat that it had been used but reasonably well maintained. This is our first boat and from reading the boards I have learned a great deal about my new found love. The motor is starting to show its age an is now running in the mid 90 lbs of compression per cylinder. Given the fact that my hull is rated for 130 HP and the 88 even making optimum power would be underpowered for this hull makes me believe thatrebuilding this motor this winter seems like throwing good money after bad.
I tell you all this to help frame a question I would like to ask you all. Would you look at an older 120-130 HP motor that is in decent shape (110+ compression and otherwise mechanically sound) that can be had for next to nothing or am I better off spending what I spent on the whole set-up ($4000) and dropping the money on a used but newer motor?
Thanks
Jason
Thanks
Jason
