what yamaha control box ???
defcondaze
i have a 115 yahama and the only contols i have are for for a 65hp johnson electric shift.<br />model #115ETLK<br />i believe its a 85 , what type of control box do i need to make this work ? is it electric shift also or do i need another cable ? <br />thanks
defcondaze
Re: what yamaha control box ???
yes i know , do you have anything more specific ..then just yamaha control box
rodbolt
aqua<br /> without anymore info its hard,<br /> all control boxes from yamaha can be had with or without the power trim switch. the side mount box with ign harness is a 703 from yamaha and the binnicle is a 704, the 704 does not have the wiriring harness for the engine..<br /> a model number from your 115 is needed.<br /> the ign harness on the v4-v6 motors is a 10 pin harness that has not changed since the early 80's. there are some 7 pin harness's that wont work on your application.<br /> are you looking for a flush mount,side mount or binnicle mont control ?
defcondaze
ill givve you some more info ........... its 2 stroke,V4,2 carbs, it has oil injection on it it has power trim with the button on the engine , the main connector has 10 pins 7 around as a horseshoe and 3 more pins at the bottom of the others, the other 2 connectors 1- 4 pins, and 1- four holes seems like the power tilt has 4 individual single wire connections.<br />in my orig post ... model #115ETLK of engine,looking for a side mount box
rodbolt
K will make it a 1985 model.<br /> for a side mount box you will need a 703 with a harness and power trim switch, a oil harness from engine to oil tank, a alarm harness with round connectors from engine to tach and a trim harness with round connectors from engine to tach, you will also need the harness from the 4 wire pig tail on the 703 to the tach/gauge panal assy.<br /> seeing as you dislike giving any information as to control box type thats about all for now.<br /> a yamaha rigging manual would be helpful to ya about now.
