What Yamaha Prop
jls02
I have a 90HP 1986 yamaha outboard and need a new prop. It is on a 17.5 ft fish and ski procraft. What size and prop should I get? Best all around usage?
ivar
Re: What Yamaha Prop
What size and make prop do you currently have, and what is your rpm and speed numbers?
Normal for a 90HP Yamaha on a 17' boat would be something like a 13 1/4x17"
jls02
Thanks I cannot find the info on the prop I have it is all torn up.
ivar
Is the prop white painted aluminum?
If the prop you got now is all torn up and corroded, just swapping to a new "oem-style" aluminum prop should give you a nice improvement in performance. You can buy one here at iboats for less than $100.
What rpm and speed are you doing?
Ayuh,....
Have you taken the prop Off,+ Looked,..??..??
The #s are usually Under the Prop Nut....
ivar
But on a 20 years old aluminum prop, those numbers can be hard to read sometimes...
