what year 30hp tohatsu
jimfnq
Hi can u help me find out what year my outboard is?
Its a 30hp Tohatsu the numbers on the engine are 2wt68d and 346-02010
The number on the inside of lower engine cover is 346-67100-0
Thanks for your help
pvanv
Re: what year 30hp tohatsu
Year is irrelevant for servicing. Model is critical. What is the model? Is this a 4-stroke (doubtful) or a 2-stroke?
jimfnq
2 stroke and i dont no any info about this outboard apart from the numbers that i can see any info would be appreciated i am trying to get a impeller and carb kit for it
jimfnq
The reason i am trying to get these parts is the motor is running ruff and cavtivating when trolling at slow speed. Also no water out tail but will run fine and pump slow stream of water at cruising speed
pvanv
Call Tohatsu America at 214 420 6440 with the numbers you have, and they may help you id the specific model, which is probably M30Ax. 02010 is probably the serial number.
jimfnq
Thanks but i am from australia do u have the aus number by any chance thanks again for your help
