What year and model is this?
Vic.S
Re: What year and model is this?
10 not IO ??
V4M-10 and V4ML-10 are 1964 90hp Johnsons.
Presumably V4ML-10 is the longshaft version
BlueGhost93
Ah that's it. Tag was hard to read. Is that a good model? I have the opportunity to pick one up but it will need a prop and iboats doesn't seem to have a aluminum prop for it. And the price of the stainless is ridiculous.
Joe Reeves
Props are available just about anywhere but that's the least of your possible problems.
That was the first 90hp model manufactured which had/has a four barrel carburetor of which parts will be quite hard to find. The lower unit is an electric shift model which may be problematic... bad hub, bad shift spring... both of which would also be hard to find and even if found would be outrageously expensive.
In my humble opinion, although I usually brag up all of the OMC engines... this one was not a good design. Unless you're picking it up for a song, so to speak... beware.
BlueGhost93
I passed on it. To many factors like you said above
