What year is my Evinrude 70?
V2
Model# is: 70973R<br />Serial# is: J0003680<br /><br />I need a lower unit for it.<br /><br />Thanks
Rex
Re: What year is my Evinrude 70?
IT'S A 70 H.P. AND A 1973 ENGINE
Rod Holder
Gotta agree w/ Rex. I have a 1973 65hp and the model is 65373R. I could not find my owners manual but I think the "R" means long shaft.<br />Hey, mine is new to me so I don't know how long it has done it, or if it did it before I replaced the water pump, but I get alot of water squirting out the drain notch where the lower unit meets the upper (in front).<br />Does yours do that ? Mine seems to pump fine as I get water from the exhaust reliefs and the lower outlets.<br /><br />Give me a shout...........
G DANE
Rod Holder<br /><br />You asked this question in former thread. I just started up my old 1974 25Hp i rebuild this winther. I can tell you,it does too. Water runs like from a slow crane, from the two holes just beyond the bolt lewel, where the lower unit bolts on. But lots of water at thermostat. ( you can check cooling by removing thermostat cover on smaller models) I guess this water leves the pump through a worn waterpump housing, at shaft, as i only replaced impeller.
Kiwi
According to my records V2 you have a 1979 engine. Evinrude 70hp model numbers 70973 thru to 70979 were manufactured during 1979.<br /><br />Mike
