What year is my Johnson 60 Hp
Patty Pooh
model # VXL-13A<br />Can I use Spray Carb Cleaner to clean carbs while <br />motor is running?
ob
Re: What year is my Johnson 60 Hp
Patty ,April 16 at approx 9.PM you were informed that your motor was a 1967 model.April 16 at approx 11:16 pm you titled your post "Problem with 1967 Johnson 4 cylinder." Now you ask the year model once again.I don't get it. :confused: You were already informed that carb cleaner by itself run through the carbs would not be adequate in removing any possible blockage without dismantling,on April 16 as well. :confused:
