What year is my motor? Evinrude fisherman 6hp 6102E J03388
McBoatin
What year is my motor? Evinrude fisherman 6hp 6102E J03388 are the only numbers i found on it stamped into the motor.
can anyone point me to some info as I just bought the motor. It has not been run in 10yrs but had no metal in lower gear unit. had spark, feels like it has compression (need a compression gauge!) looks clean overall.
but I need to know what the fuel mixture is? what year would help!
thanks guys. with out you I would be up a river without a paddle
CATransplant
Re: What year is my motor? Evinrude fisherman 6hp 6102E J03388
50:1 is the ratio for your 6hp.
McBoatin
thanks guys! she runs great!
but there is a fuel delivery problem as it will die if i dont continuously pump the fuel primer bulb on the fuel line from the gas tank to the fuel pump.
any ideas? thinking bad carb float? I will take off the fuel line to the carb and see if it pumps fuel.
