what year is my rude
bgross
I have a 35hp evinrude with model # E35ECIG and serial # E0002031. I am wondering the year of the engine and also what diameter and pitch of prop I should put on it. The present prop has a # on the outside PW6937, it is a three blade and the engine operating range is 500 to 6000 rpm, 35hp @ 5500 rpm.
kenmyfam
Re: what year is my rude
I thiunk it is an 81 as well but you may have missed the shaft length letter.
Vic.S
It is a 1981
CI are the date letters.
The absence of a shaft length letter indiactes that it is a standard (15") shaft
A post on the "Props questions and topics" board may bring forth some help with the prop selection
JBIII
If you don't already know this the correct prop dia. should be in the manual (I would guess 10 1/2) but the pitch will depend on the size, shape and weight of the boat.
I have an 1984 35hp long shaft rude on an old 16' alum. semi V hull. 2 batteries, 2, 6 Gal. tanks, raised casting decks, live wells, pumps, electronics etc. It's heavy.
It has a 10 1/2" Dia. x 9" pitch. At WOT it runs 5100 RPM, 32MPH by the GPS. I'm not quite in the power band but MW doesn't make a vortex 7 or 8 pitch, yet.
Vic.S
The props listed for the model are:
0387320 .. 11-1/4 X 7
0391064 .. 10 X 17
0386637 .. 10-1/2 X 11
0386933 .. 10 X 13
0386317 .. 11 X 9
0387525 .. 10-1/2 X 11 SST
0387526 .. 11 X 9 SST
0388866 .. 10 X 13 SST
0390731 .. 10 X 17 SST
A sales 1984 brochure gives the standard prop as 10x 15 though
JeffGoldberg
I have a 75 hp Starlite V Four electric shift motor with the Model #75393E Serial # E03696 any ideas what year this motor is. Thanks in advance.
Vic.S
75393 is 1963.
But why on earth have you hidden the request under someone else's post. You should have started a thread of your own. Its a miracle i saw it at all.
