what year is this 85 hp johnson
mikeperry
I need to know what year this 85 johnson is? ser.#j3031008 model # 85esl69e Is this motor a hydro-electric shift or what? I can buy it for $200. It is on a 16 ft. boat.Is it a reliable motor? :confused: :confused: :confused:
Dhadley
Re: what year is this 85 hp johnson
1969. Yes it is a hydro-electric shift motor.
ledgefinder
Ensign
Good price, as long as you don't have to put tons into it to get it running right. <br /><br />Check compression. Ideally you want to lake test it so see how it runs under load, how it idles, how it shifts, and how it cools. After the lake test, see how the lower unit fluid looks - it shouldn't be 'milky' as that indicates water intrusion. If you can't lake test it, recognize that you're taking a risk & decide if it's worth it. Hopefully you can see it run in the driveway anyway (use flushmuffs - never run the motor without water). The problem is lots of really sick motors will sound good in the driveway. Check the lower unit fluid even if you can't make it to lake.
mikeperry
Thanks guys for responding to my question so quikly.I'm not going to buy the motor seeing how it's an electric shift because of all the problems that i've had with my 1971 50hp. johnson
mikeperry
P.S. can you please respond to my other question posted on may 12 2005, topic is ==1971 johnson 50hp. won't plane. thank you for your time and knowledge.
