What Year....Model number??
phishinout
Is there a way to find out what year this motor is:
110hp Johnson
Model number: J110TLCDC
Ser no: J7144189
Thanks for the info!
bob johnson
Re: What Year....Model number??
Thanks.....how did you know that???
in the year your motor was made OMC was using a coded system for describing outboard models and their differnces
there are several sources for looking up that resource.
but it is based on the first letter calling out the manufacturer( american versions..foreigns motors are differnt from OMC)
J= johnson
E=evinrude
the next number is the horsepower yours=110
the next letter tells if it is a manual trim or an electric trim and if it is electric start
T= electric start power tilt and trim
the next letter is the shaft length
L= long
( I forget the other two designations they may be S for short and X for Xtra long...not 100 % sure there)
the next 2 letters are the last digits of the year of the motor
and they are assigned in on the word INTRODUCES
I=1
N=2
T=3
R=4
O=5
D=6
U=7
C=8
E=9
S=0
your motor being CD = 86
the last letter may or may not be there and it has nothign to do with the model identification...it is a code used at the factory for something
wow....that probably was a few places on the search button!!!
bob
EN2
short shaft engines, no L.
phishinout
Thanks for the help guys...........that was very informative. Now I will be able to help out my buddy that has a similar motor.
fortyfreak9
Or you could try google, that always worked for me.
bob johnson
I found my sheet that expplains the model designations...and the space wee the "T" went in the OP actually has a whole bunch of possiblities. and only a few are wether it is a manual or power trim.
for example my 90 hp Ocean Pro has an SL designation there for 60* V trim and tilt!!
also for the shaft lengths they list
15"= (blank)
20"=L
22.5"=Y
25"=X
30"=Z
these designations apply from 1980-2004 my paper says
bob
ezeke
This covers most of the recreational models 1980 and up. (Please click the thumbnails.)
