Re: What year of SEAKING
Oh, I can explain that a bit. Since your original posting was in the Johnny/Rude section, I just assumed.<br />The Gale division of OMC manufactured outboards for a number of retail clients like Mongomery Wards (Sea King), Eaton's up here (Viking outboards), even Goodyear (Sea Bee). OMC, or the Outboard Marine Corp, had a number of division including Johnson, Evinrude, Lawn-Boy, and others.<br />So OMC used the same basic parts in building Gale outboards as they did in the Johnson and Evinrude lines. The 5hp Gale is equivalent to a 5.5hp Johnson/Evinrude. So parts that fit the 5.5hp also fit your 5hp Gale, and parts are abundant for the 5.5hp. If you can't get them from your local Bombardier dealer, Iboats carries a number of aftermarket parts as does NAPA.<br />The specs are also the same:<br />Fuel/Oil Mix: 24:1 87 octane gas to TCW-3 outboard oil. (And stick with it, you have plain bearings in that engine)<br />Plug: Champion J6C (was J6J) gapped at .030"<br />WOT RPMS: 4000<br />Displacement: 8.84CID<br /><br />I hope this answers your questions!
