What Yeart
allanb55
Hello I am a nebie and was wondering if any of you could tell me what year my Johnson Sea-horse may be? Model# QD-21 s or serial# 2113500. Thanks for any responce.
Paul Moir
Re: What Yeart
Welcome to Iboats, allanb!<br />Here's the Yeart plus more:<br /><br />Johnson Model QD-21<br />Year: 1960<br />HP: 10<br />WOT RPMS: 4000<br />Displacement: 16.6 cu.in. = 272.0 ccm<br />Cylinders: 2<br />Weight: 67 lbs. = 30.4 Kg<br />Gear ratio: 15:26<br />Fuel/Oil mix: 24:1 87 Octane gas to TCW-3 rated outboard oil.<br />Spark plugs: Champion J6C (was J6J) Gapped at .030<br /><br /> Picture.
allanb55
Re: What Yeart
Thanks Paul, can you tell me where I should see the water exiting from the motor? beacause tight now it is comeing out two holes in the front of the motor not sure if this is right. When I plug the holes it just comes out further up does not seem right
Paul Moir
Re: What Yeart
I'm not sure which holes you're talking about, but there is no 'tell tale' like on modern engines.<br />Water should gush from the large hole on the propeller side of the engine, half-way up the mid-section, after the engine warms up and the thermostat opens.<br />If you can hold your fingers on the top of the engine block for three seconds, you're probably not overheating.<br /><br />Do you mean the water is coming out from just below the engine itself, or under the hood?<br /><br />I hope this helps!
allanb55
Re: What Yeart
just down and across from that large hole, some water does come out from the large one but just spits and sputters, can you tell me if there is a tube that the water exits, maybe something is bad inside, yes this did help thanks again
Paul Moir
Re: What Yeart
So these holes are in the mid-section, not the lower unit? You had the water up to the seam between the lower unit and the midsection right? The water pump must be submerged to work properly at idle. The water pump is located at the seam between the lower unit and the mid-section.<br />All water is supposed to exit from the hole at the back of the engine. After the thermostat opens.
allanb55
Re: What Yeart
yes these holes are in the mid section, and maybe I should rethink how i was testing, a barrel of water maybe was not enogh, Thank you for your help it was appriciated and very helpfull, any other thoughts you could add would be great.
Paul Moir
Re: What Yeart
Keep an eye on the powerhead while you test it. You should be able to hold your hand on it for a couple seconds. It should be hot though.<br />I suspect what you're looking at is just some spurts from the water pump. I hope so anyway. If you're having an overheating problem, perhaps the powerhead base gasket is leaking, or there's a leak in the water tube.<br />An excellent way to test for good water flow is to remove the thermostat from the cylinder head, leave the thermostat cover off, and start the engine. Water should gush vigorously out through the hole that the thermostat goes in.<br /><br />Good luck!
