Engine Model: 1995 Mercury 135XL
Problem: Low oil warning - Engine will run fine for about 5-10 min. then the warning starts. Engine will only idle because control unit cuts fire to #4  cylinders. Have repeated this whether on the lake or in the driveway with water muffs on several times.
Checks performed: Pulled oil pump inspected gear on shaft and teflon worm gear inside block with a flashlight while turning the flywheel by hand - all OK( no black shavings, no corrosion, no pitting, etc.) Magnet on oil pump coupler is in place and OK. Oil tank under cowl full to the point of overflowing - OK. While engine is running; getting ~1-2volts DC (pulsing) across the blue and blue/wht lead coming off of the pump shaft sensor - I assusme this is OK. Connected a remote fuel tank 50:1 to the engine to test(3 min. @ 1500rpm) oil pump output; results 5-7.5 cc's of oil - I also assume this is within range.
Question: Would it be safe to say I narrowed it down to either the pump shaft sensor, the oil warning control unit, or both? I'm leaning towards the black box for the oil warning control.
Any input would be greatly appreciated. Thanks
