OK, not my first rodeo but I could use some input on this. I dragged a wellcraft 19.6 home the other week. I like the hull and am going to set it up for cruising and fishing in the sound and inshore. It currently has a mercruiser 470 in it that recently seized up. no water in the oil and it was properly winterized from what I can tell. I'm assuming before taking it apart that a manifold leaked water into a cylinder or cylinders and it rusted in place. I've pulled the drive and checked it out. It pressure fine and seems to be in decent shape. I'm considering 2 options:
1. Tear the 4 cylinder apart and rebuild it using an aluminum ford head, new manifold assembly, 4bbl carb, add an external alternator kit, etc... This kind of sounds like fun and I like the idea of the lightweight engine back there. It also sounds like it could become a relatively expensive proposition pretty quickly.
2. I know where I can pick up a "project boat" that has a serviceable 4.3 with low hours and an alpha drive for under a grand. The boat hull is damaged and would go to the dump. I also have another use for some of the drive gimbal and bell housing parts. I'm leaning this direction overall especially since I have spare alpha drives and parts, spare alternator, starter, etc, etc, etc... for 5.7 / 4.3 alpha set up. a couple specific questions:
Aside from having to build structure under the engine mounts in the wellcraft for the 4.3, what else would I have to change? Is there any way I can use the 470 drive and transom assembly with the 4.3? I'd love to not have to tear everything apart if I don't have to.
How much heavier is a 4.3 than a 470? I've got a good handle on the 4.3, but don't know about the 4 cyl.
Thanks for any input or experience you have to share!
