I just picked up a princecraft super pro 176 and it as a 1897 v4 110 johnson on it. I wanted to do a compression test on it which went well! Iput the motor in a big tote filled with water so it wouldnt be so loud in the neighbour hood. When i did this one side of the engine got way hotter then the other. The port side was at 120 while starboard hit 185. I shut it right down when i noticed that. BUT when i run it on the garden hose with the ears, both sides dont got over 130?? what could be the problem if any? im hoping to get it into the water this weekend and do a temp check at the dock before heading out
