Hello all,<br /><br />As usual I'm seeking advice from the pro's. For the last 24hrs. my motor has been tilted all the way up, as I'm doing some work on the prop. Today I noticed what appears to be a very oily mixture dripping down the side of the motor. It smells like gas, but it's thick and dirty like motor oil? I dropped the motor back down, and took a look inside, the oily stuff is all over the place. Do I have a seal or gasket leak, are the carb floats stuck when tilted? The motor runs great, but this has me a bit concerned!! The motor is a 1972 Johnson 50hp electric start, hydro-electric gear case, two cylinder, two cycle. If you guy have any ideas or suggestions on where to start, I'm all ears! Thanks, Ross
