if anyone has read past threads i had a piston basically overheat and melt in the cylinder. i'm waiting for the manual to arrive to start that whole tear down process. i'm really looking to narrow down what actually caused this. i started with removing and disassembling the carbs hoping to find some sort of blockage in the jets. found nothing. i was really surprised how spotless these things were. i did have a problem with water in the oil tank that i thought i took care of. i'm kind of thinking that may have caused that piston to over heat a time or two and it finally s...t the bed when i was able to get the engine up to speed. none of the other cylinders were harmed. from what i can see. new to this whole thing so im wondering what i should check next. any suggestions are very welcome! thanks guys, you have been great through this whole process. oh the engine is a 95 johnson 90hp. j9tleor
