73Chrysler105
- Joined
- Sep 10, 2009
- 407
I have had a lot of differing opinions on this and wanted to see if we could get a consensus on the subject.
I have my hull on a stand but not sure if I am going to put a hook in it on the stand and if I already have whats the best way to determine if I will have a hook in the hull.
I have attempted to square the hull out on the stand its on by picking a point from each corner and drilling a hole in the rub rail area. I ran a line crisscrossed and made sure that from each hole to hole was the same distance which should mean its square but since I am dealing with a hull with the cap removed it also could mean one side is still push in more than the other. Should I do it from the point on the bow to the rear corners of the boat as well?
Should I have a bunk board styled stand like a trailer will that keep it from getting a hook or would it be better to more support the sides and keel?
Just looking for a consensus of opinions here that might help me and others.
