What's the difference between these 2 types of PT&T units?
ezmobee
Ebay item: 250102550908
Ebay item: 230115507930
I noticed the first one is only called a power tilt unit. Does that mean it can only be used to raise the motor all the way up or down and not be used to trim it out?
F_R
Re: What's the difference between these 2 types of PT&T units?
That is correct, the first one is only for tilting. It will not support the motor under power in partial tilt (trim) positions. The second one is trim and tilt. Make sure it fits whatever you want to put it on before buying. They are not universal.
ezmobee
Bummer. I knew the deal I was getting on the first type of unit from a salvage place was too good to be true. Could the first type be used to trim the motor up enough to get off a sandbar or something like that? I don't necessarily need the ability to trim my motor at speed.
F_R
It will hold it up at idle, but will squish down at anything much above that.
