what's the easiest order to install bellows
jonny rotten
Installing new shifter cable, u joint and exhaust bellows.
Is there any particular order to install them that makes things easier?
I'm using a tube instead of full exhaust bellow for ease if that makes a difference. Also changing the trim sensors but it doesn't seem as it it matters if those go on before or after bellows?
Everything is off and ready for install at this point. I've never done this so all advice/tips welcome
Mercruiser Alpha one
Ayuh,..... Follow the links in the Adults Only section to the Merc factory manuals, 'n follow Merc's procedure,....
If I remember correctly, shift cable bellows first because the cable will slide in it. then water hose, drive bellows and exhaust last
