chum1
- Joined
- Apr 15, 2010
- 359
Just picked up a 1977 85 hp merc for $200 with a lower unit thats stuck in forward, thought that would be an easy fix but was wrong, after trying to remove the locknut with my special tool, i found out it was froze solid, had to drill some holes carefully then use a chisel to break it out.
I'm sure it wouldnt havent budged even with factory tools, thought all right just need to pull out carrier, find parts then reassemble........Wrong!!, the bearing carrier is in solid, Ive tried heat,wd40, pb blaster, super duper snake oil and the works, even used an aircraft rivet gun under the washers of the prop lock nut, it will not budge! I know there is a special puller for this and have tried using the prop nut with some misc. chunks of metal braced against the housing but no luck.
Any ideas on clearing this hurdle? Here are some pics of the ordeal
