Re: Whats the trick????
It's all technique. Minor changes in body position can make all the difference. I rest my arms on TOP of my knees,that makes a difference with some riders. Generally as others have said, let the boat do the work. The less you do the better. When you start off, all tucked up, try not to move position or stand until the board has come out of the water and has planed completely. At that point you'll naturally turn to whatever stance is comfortable as you straighten your legs and stand up.
However, if you weigh 300lbs and are using a 134cm board its never going to work. Other factors have to be considered.
Is the board just ploughing through the water when the driver 'hits it'? If so then work on technique. If no,t maybe have the driver ease forward on the throttle gradually so it's a slower and steadier movement.
Good luck, a tower is not essential by any means!
D
